The model is AN-PR1000
ERR80 indicates a problem reading valid data from the EEPROM at power-on ("Protect area read error").
It is probably necessary to replace the EEPROM to fix this.
It is then necessary to re-set valid values for each address in the EEPROM by following the instructions in the link below:
https://electronicshelponline.blogspot.com/2016/02/sharp-pr1000h-home-cinema-system-test.html
You may need a repair center to do this for you if you are unable to do it yourself. A Sharp specialist should be familiar with this procedure.
You could try the re-set procedure first without replacing the EEPROM in case it's just a data loss.
You may also find this useful:
https://electro-medical.blogspot.com/2015/12/sharp-pr1000h-home-cinema-system-test.html
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
SOURCE: Remote code for Sony Home Theater
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
SOURCE: Model - HP Laserjet P2055dn. Issue - 49 Err
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
