Hello Bryan, that error indication (DVD894) is indicating that you can not read the disc, try using some CD cleaner and test, you can also clean the lens with a cotton swab and a drop of isopropyl alcohol
But, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Bryan, esa indicaci?n de error (DVD894) esta indicando que no se puede leer el disco, prueba usar alg?n CD limpiador y prueba, tambi?n puedes limpiar el lente con un hisopo de algod?n y una gota de alcohol isopropilico
Sino, busca un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
SOURCE: anyone know the all region codes for Panasonic SA-PT875 dvd
HELLO!
The main problem with Panasonic DVD units is they are locked to a certain region. The vast majority CANNOT be hacked via the remote control unit and please be warned there some websites who offer strings of codes (with many many numbers) and they are not guaranteed to work - in fact - some can screw up your machine for good.
My advice: take it to a local service centre who will unlock your machine properly!
GOOD LUCK!
SOURCE: error LSU
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
SOURCE: panasonic sa ht 540 fault
my panasonic sa ht540 starts up and then says f61 then goes to stanby
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
SOURCE: COMO FAÇO PARA RESOLVER ESSE
i have this error 0xc05d0281 em hp photosmart 3313 all-in-one.
what can i do?
