Hello, indicate model of the TP-Link that you are commenting, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola, indica modelo del TP-Link que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
My TP-Link is the TL- WA85ORE
Hi, I sent you the link to download the user manual
I hope you can solve the problem
Hola , te envio el link para que descargues el manual de usuario
Espero puedas resolver el problema
Saludos Franco Dosilhttps://static.tp-link.com/res/down/doc/...https://www.manualslib.com/manual/448462...
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
SOURCE: acer aspire 3000 wi fi problem
First you need to make sure the Wireless drivers are installed in the computer, aswell the Acer Related utilities. Then Most acer laptops have a button on one of the sides or on the top of the laptop to turn on the wireless.
To find out if you have the acer related programs installed, try pressing some of the buttons on the top of the laptop, that are NOT apart of the keyboard, they should open up acer or related programs, if noting happens the programs are not installed, one of the buttons is likely to turn on the wireless.
To check if the wireless drivers are installed press start -> run -> type: msinfo32 (OR press down the windows key and press R, then let go and type msinfo32 into the run menu that comes up and click OK)
On the program, left side, open up components from the + next to it, then find Problem devices from the list and click on it, on the right you will see a list of devices that are not installed or not working.
If the list is empty, everything is properly installed. and you should be able to get your wireless to turn on by pressing on the wireless button on the laptop, and then use your computer to connect to a wireless network.
If you need further assistance let me know.
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
SOURCE: trying to enable the wi-fi on my acer 3693WLMi
install an application called 'Launch Manager' That will help.
You didn't say what model?
Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
If you don;t have the drivers go to the Acer site and download them, and install.
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
