The aternator stator is undeneath the engine flywheel. So not a simple component to replace. You can easily test (relatively easy) the stator without removing the fly wheel.
More likely it's a bad connection or voltage regulator.
Yes but Test voltage regulator first.Then check wiring connections.Dirt in plugin connections etc.
SOURCE: replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
