20 Most Recent Toro 1800 Power Curve Questions & Answers
manual
manual
2answers
Stopped working
clean the gas out of it make a new batch of 50to 1 mix 2+2 oil make sure you close choke to start it and open after it starts or you will foul out the plug , when they sit the gas goes bad , make sure you are getting spark to the plug always empty the carb when stored and run it until it shuts of by itself , will last longer
12/3/2017 2:44:09 PM • Toro 1800 Power... • Answered on Dec 03, 2017
SNOW BLOWER TORO POWER CURVE STOP WARKING POWER BARCONTROL P
adjust the cable at the bottom will work again
12/3/2017 12:39:42 PM • Toro 1800 Power... • Answered on Dec 03, 2017
I need to replace a defond switch for a Toro snowthrower. It doesn't come apart. Do I just stuff the wires in?
Howdie go and look on YouTube They got Everything to show ya thks for your time
1/5/2015 12:01:30 AM • Toro 1800 Power... • Answered on Jan 05, 2015
0answers
2answers
Toro CCR 2450 Snowblower has new plug & gas but will only start with added starter fluid then will run until trying to start again.
Question edited for clarity. When you put it away at the end of last snow season, I expect you just rolled it to the corner of the garage and left it until now? The two stroke gas in the carburetor, went bad and gummy. It starts on starter fluid because no gas is coming from the carb. https://www.google.com/search?q=toro+ccr+2450+carburetor+cleaning ..
1/20/2024 9:51:29 AM • Toro Garden • Answered on Jan 20, 2024
We have a Toro Powervac that will not start. Vac has a new carburetor, new engine coil, new fuel lines, new spark plug and still will not start. Any suggestions?
did you make sure it has spark. i have learned over the years because an electronic is new doesn't mean its good? If it has spark remove the plug and put a bit of gas in the hole and re install plug see if it will fire on that gas. if it does its the carb something is probably blocking fuel. check the compression if its low compression it will not run. if u dont have a compression checker just remove the plug stick your finger tight over the plug hole and pull it over it should blow your finger off the hole.
9/17/2023 6:54:34 AM • Toro Garden • Answered on Sep 17, 2023
Hi, I would like to know what is the typical compression value of a Kohler 16HP singel cylinder engine?
Yes, decompression lowers cylinder pressure during low rpm while cranking. If you're concerned with compression, you need to do a leakdown test. Inexpensive (~$30) units are available through numerous eVendors. The leakdown test provides a metered volume of air that is translated and displayed on a pressure gauge simply labeled high (excessive leakage), moderate, or low (nominal leakage).
It's an L-head engine and once they get a few hundred hours run time, the valves wear into the hard seat, lash goes to zero, and they become hard to start. You can check valve lash by removing the crankcase breather (two screws). If lash is near zero, time for a valve job. Plenty of how to videos on the web. If it's easy start, just low power then less likely a valve lash issue.
There are many things that cause low power. Bad fuel, water in fuel (fuel bowl), fouled carburetor, poor spark, fouled plug, improper plug gap, wrong plug, weak ignition module.
9/12/2023 10:24:23 AM • Toro Garden • Answered on Sep 12, 2023
Toro riding mower stopped moving
If you have no forward, no reverse but the motor is still running normally the most likely reason for this is the main drive belt. This connects the motor to the transmission. If it stretches, breaks or drops off the drive pulleys you will lose all movement.
8/21/2023 3:49:43 PM • Toro Garden • Answered on Aug 21, 2023
Why does my Toro Titan HD 2000 series 74467 blow a fuse every time I engage The blade?
My thought is the seat safety switch is faulty, because normally these mowers won't work unless someone is sitting in the seat when if goes into the blade drive. There are other ideas in the videos. Frayed wires in the harness somewhere?
4/29/2023 6:19:25 PM • Toro Garden • Answered on Apr 29, 2023
I have an electric Toro 1500 Power Curve snow blower and it makes a high pitch squeal when I turn on the blower. Possible bearing issue?
Yes, a high-pitched squeal coming from your electric snow blower when you turn on the blower could indicate a bearing issue. The blower motor is typically equipped with bearings to reduce friction and allow the motor to run smoothly. Over time, these bearings can wear out or become damaged, resulting in a squealing or grinding noise. If you suspect a bearing issue, it's important to have your snow blower inspected and repaired by a qualified technician or service center. Attempting to repair the snow blower on your own could be dangerous and may cause further damage to the machine.
3/9/2023 3:02:46 PM • Toro Garden • Answered on Mar 09, 2023
52 toro Z Master 2000 series won't start
There could be a few different reasons why your Toro Z Master 2000 series lawn mower won't start. Here are some things to check:
  1. Fuel: Make sure that the gas tank is full and that the fuel is fresh. If the fuel is stale or contaminated, it may not be able to properly power the engine.
  2. Spark plug: Check the spark plug to make sure it is clean and in good condition. A dirty or faulty spark plug can prevent the engine from starting.
  3. Air filter: A dirty air filter can restrict the flow of air to the engine, causing it to run poorly or not start at all. Check the air filter and clean or replace it if necessary.
  4. Battery: If the battery is dead or not fully charged, the engine may not start. Charge the battery or replace it if necessary.
  5. Ignition switch: Make sure the ignition switch is in the "on" position and that the safety switch is engaged.
If you have checked all of these things and the lawn mower still won't start, it may be a more serious issue that requires professional repair.
1/8/2023 5:42:24 AM • Toro Garden • Answered on Jan 08, 2023
Toro 51352 line breaks immediately
  1. Make sure the line size is correct and compatible with your trimmer. Using a line size that is too small or too large can cause problems with the trimmer.
  2. Check the spool for any debris or foreign objects that may be causing the line to break.
  3. Check the line for any kinks or knots that may be causing it to break.
  4. Make sure the trimmer is properly calibrated and that the line feed mechanism is functioning properly.
1/3/2023 11:24:11 PM • Toro Garden • Answered on Jan 03, 2023
Could you show me Spring locations on Toro LX466 tractor mower deck
https://www.youtube.com/watch?v=JzO0s_MLVXA
12/4/2022 5:04:03 AM • Toro Garden • Answered on Dec 04, 2022
Toro 14 38 hxl
if it has flat tires your thinkig its not disengaging but it is it does not want to roll on flat tires shove it back and forth till it rolls once you have tranny disengaged nothing holds it that should get you home then we can work on the rest
10/20/2022 6:18:56 PM • Toro Garden • Answered on Oct 20, 2022
Toro 1800 Power Curve Logo
6 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
stopped working
  • Garden
