Your fuel and air adjustment needle valves are out of adjustment. On the carburetor look for two small screws next to each other. You will need to adjust those screws. The one closest to the air cleaner is the air adjustment screw, and the other is fuel. If you mess up the adjustments where it will not start, screw both screws in all the way (do not force them), and back both out one and a half turns. the trimmer will start... make more adjustments form there.
Fouled carburetor or crankcase leak.
SOURCE: My Echo GT-200R will not start.
you need to make sure your plug is sparking
and if it is wet then the engine is flooded with fuel
press your primer bulb 5 or 6 times and use no choke and hold throttle open when trying to start it
If you have not had a solution by now (I know it's been a month since your post...), I just read on another help site that by cleaning the exhaust port would solve the problem. That port gets gunked up and the motor won't work if it can't "exhale" correctly. Good luck.
SOURCE: Primer bulb stays in after depressing it.
sounds as though fuel lines are incorrectly hooked up
Testimonial: "Echo GT 200R Grass Trimmer.Fuel lines were correct.I had purge base gaskets on wrong side of carb.I replaced gaskets but still won't start.Carb cleane"
SOURCE: what is mixed with the fuel for the Echo GT-200r weedeat trimmer
The mix is 50 to 1. Get an owner's manual for free here. http://www.echo-usa.com/documentation.asp?Model=GT-200R&lang=E Have a great day.
SOURCE: how to restring echo gt 200r weedeater
how can i download the manual for my echo trimmer showing me with pictures how to restring?
