SOURCE: I need the code for a Teac CD-X10i mini hi fi
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software
you can download from here.
Once installed, you will simply
run the software, and select the devices you would like to control from
menus. The software finds the right codes for you and loads them into
your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual
Download
Logitech Harmony
Firmware Update
Harmony Win Software
Download
Logitech Harmony Safe
Mode Fix
Harmony Remote Glow
Light Fix
SOURCE: my teac micro hi-fi system CD-X10i doesnt work
many units have a fuse inside the back cover near where the power cable comes in. be careful to replace it with the same size fuse as the problem that blew the fuse might still be there and could potentially cause a fire.
I have the same unit and i am looking for help because the cd will not run (wont spin the cd), but the door works. also the FM reception sucks.
Larry
SOURCE: Does the Teac Micro Hi-Fi
Regards,
Tony
