SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
SOURCE: Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Testimonial: "I can't believe with all that space in front that they didn't include a display panel for cd tracking. Since the unit plays cd's, why wouldn't it have a front display panel?"
SOURCE: i have a magnavox model 40ME324V/F7 tv that wont turn on
Take the back off and see if the main fuse is blown, if it is and chances are it will be, if your comfortable soldering in new components order this kit from Shopjimmy.. http://www.shopjimmy.com/magnavox-a4g25mpw-001-ba4g25f0102-1-power-supply-unit-repair-kit.htm
