20 Most Recent
Magnavox 32ME303V/F7 32" LED TV 1366x768, 60 Hz, HDTV Questions & Answers
Magnavox model 32me303v/f7 power on red light blinks then flashes the screen then just black screen but red light is still on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips & Magnavox TVs are entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
See the sites in Magazine view.
5/21/2023 10:40:10 PM •
Magnavox...
Answered
on May 21, 2023
VCR/DVD code for a Magnavox?
Your question is lacking in details.
You have an unknown make of VCR or DVD and you want the Magnavox television to operate them?
Or you want the VCR and DVD remote to operate the television.
Or you want a Universal Remote and a magic code to make all three work?
The answer to all three is No, apart from number 3 where a very expensive LCD computerized remote can control multiple items.
No one uses Universal remotes, there are better options. Codes are based on the MAKE of the unit to be operated, so Philips DVD you want a Philips DVD remote code. For the Magnavox, you want the code for a Magnavox television IF in fact it is a television and not the VCR/DVD, which now I am thinking is actually what you are after, so we end up here!
https://theproductanalyst.com/magnavox-dvd-vcr-combo-remote-codes/
But better to buy a remote actually made for that unit as explained here.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
12/2/2023 12:55:29 AM •
Magnavox...
Answered
on Dec 02, 2023
I have a Magnavox clo358 universal remote what are the codes for my Magnavox DVD VCR combo
To program your Magnavox DVD VCR combo using the Magnavox CLO358 universal remote, you can try the following codes:05030675115312031321Here's how you can program the remote:Turn on your Magnavox DVD VCR combo manually.Press and hold the "Code Search" button on the remote until the indicator light turns on.Release the "Code Search" button.Press and release the mode button for the device you want to program (in this case, the DVD VCR combo). The indicator light should remain on.Enter one of the codes listed above using the numeric keypad on the remote. The indicator light should turn off after entering the code.Aim the remote at the DVD VCR combo and press the "Power" button. If the device turns off, the code is correct. If not, repeat steps 4 to 6 with the next code on the list.If none of the codes work, or if you have any other issues, it's recommended to consult the user manual of your Magnavox CLO358 universal remote for additional instructions and a complete list of codes.
8/28/2023 5:54:07 PM •
Magnavox...
Answered
on Aug 28, 2023
