I fixed your question as it got a bit mixed up!
Is this it? Product descriptions aren't model numbers :>)
Coleman 40 Quart PowerChill™ Thermoelectric Cooler
Manual, there are two
https://s7d1.scene7.com/is/content/Coleman/Canada/Product%20Manuals/5640.pdf
or this
https://images-na.ssl-images-amazon.com/images/I/814cCTUz-4S.pdf
This
https://www.coleman.com/coolers/thermoelectric-coolers/40-quart-powerchill-thermoelectric-cooler/SAP_3000001497.html
or this
https://www.coleman.com/coolers/thermoelectric-coolers/40-quart-powerchill-hot-cold-thermoelectric-cooler/SAP_3000001495.html
the manual is probably;
Plug it in - Enjoy your Coleman product.
Coleman Contact
https://www.coleman.com/support/contact-us
Request the manual from Coleman.
SOURCE: i HAVE A COLEMAL 40
Coleman 40 Quart PowerChill Thermoelectric Cooler
What diagram are you looking at? I only see one motor in the unit and it's the only one that Coleman has made for your item.
If all else fails, Coleman has a customer service line that can help, 1-800-835-3278 or you can email them at [email protected]
Hope this helps,
Glenn
SOURCE: My coleman 40 qt. powerchill keeps freezing up
This is normal due to humidity, It means your cooler is working well.
SOURCE: looking for a replacement motor
You can find the replacement motor here
Replacement Fan Motor For Coleman coolers
You need a set of basic tools including wire crimpers, cutters, soldering iron and solder and shrink wrap tubing.
they get very warm. iff you are running the cooler all the time and newer turn it off you will cause the power adapter fail.the cooler is not an appliance that is designed for constant service. your refrigerator that is plugged in and running.
