Looking at screen, in setup (outputs) {1}mode combo front, what to do next ?
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
SOURCE: Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
SOURCE: amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
SOURCE: Sound is good, but guitar input doesn't seem to
Have you tried selecting the option for microphone boost under your sound card settings (If you are using a windows operating system)? Its a check box option.
