SOURCE: Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
SOURCE: electric stapler won't staple
On the side of the stapler are the instructions - no joke - stick a flathead at the lip of the metal striker and push the flat head up - while pushing the realse at the back - use A LOT of force - that is how ours popped open. It was jammed in the back with several staples that were not visible as a jamb in the front where the staples come out. the whole magazine will pop out when it is freed.
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
