SOURCE: error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
SOURCE: I have a JENSEN CD311X car stereo!
IF THIS PROBLEM HAPPENS TO ALL CDS PLAYED, COULD BE THE OPTICALS LENS IS DIRTY, TRY TO CLEAN IT, OR IF ORGINAL CD CAN BE PLAYED THEN THE OPTICAL LENS ARE NOT PROGRAMMED TO READ THE COPIED ONES
SOURCE: cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
SOURCE: Will not play burned cd's. Getting ERROR 3 message.
have you tried using cd + or - r's and some units dont recognise all,also cd player may only read mp3 format dics, not itunes, you can reformat using software from web site....... swift sound file converter
