Cars & Trucks Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote trunk release stopped working.
The remote trunk release (from the driver side floor) on my 2001 Saturn SL1 stopped working a few days ago.
For a while, the trunk release from the key chain transmitter was iffy - it took a few button presses to open the trunk, and I think it completely stopped a few weeks ago. I can't get it to work at all now.
Are these related? How can I fix the internal trunk release?
jatncbeach
Level 2:
  • Expert 225 Answers
  • Posted on Aug 07, 2009
jatncbeach
Expert
Level 2:
Answers
225
Questions
0
Helped
93455
Points
753
See if there is power at the solenoid with the button pushed inside the car. if so change the lock solenoid. best of luck
Keyless entry and dash remote trunk release not working
Use your key to unlock the door / trunk. If your car starts up; it might just be a connector and / or your battery in your remote. Try the simple / cheaper fix check by checking the connectors leading to the trunk release solenoid.
Trunk latch
Check in the glove box for a push button to open trunk. Also along the driver's side floor sill (between the seat and the door). Along the bottom of the dash on driver's side, check there too. My son has a '92 Lesabre, and there is no trunk release-only the key opens the trunk.
The controller is bad, i have seen this many times, all other functions work good except trunk release, good day
1helpful
My 2003 Saturn Ion remote trunk release won't
Check to make sure the button on the trunk latch is turned from manual unlock...they made that feature so only the key will work to open the trunk that way if someone breaks in the front of your car they can't hit the trunk release and get into the trunk...may be the same thing for your remote. Hope that helps.
I have vw passat 2001 and the trunk will not release with remote or from drivers side have to use the key. What could be the problem
The cable from the driver side is unhooked or broken. Most likely at the catch in the trunk. Hope this help's
1helpful
Don't understand buttons on keyless entry remote fob.
If it is a factory remote it is either for the trunk release or the "panic" feature. Are the buttons not labeled?
2answers
My 2001 Dodge Durango power windows on drivers side doesn't work
auto electrician is your best avenue!
cheers Rob.
13helpful
2answers
2003 Saturn ION 2 trunk Problem
there is a manual switch that is located near the trunk latch for a safty lockout it might have been switched by accident look to make sure.hope this helps.
24helpful
3answers
2003 saturn ion-release does not work for trunk release
If only the trunk release is not working, did you check to see if the little lever arm switch on the trunk lid at the latch assembly is switched to enable the release? Mine came switched to the 'Off' position when I bought it and it took me a few days to figure that one out.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
