Acont, tcont, same thing. "ok google!!"
SOURCE: Manual J Calculations for Residential house 1018 sq. ft. American Standard unit
without actually doing a load calc it would just be an educated guess.Good choice in equipment though.
SOURCE: I need a manual of instructions for instalation of this product .
You will need plumbers putty and a plumber's drain tool. Put a ring of putty around the piece that will be on the inside of the tub to seal it. Then insert it through the hole making sure the rubber gasket is on the bottom side of the tub and tighten it down.
SOURCE: I purchased a 2005 home that was vandalized. It
They will work, most zone controls only require the use of 1H/1C thermostats, the system stages and functions are controlled by the board itself.
http://customer.honeywell.com/TechLit/pdf/PackedLit/68-0237.pdf
SOURCE: I have an American Standard gas water heater and
If you have replaced all the parts except the gas valve. Before replacing that part you might want to consider the cost. The gas valve is the most expensive part on the water heater. If the tank is older than 10 years old it may be more benificial to just buy a new water heater. Because you don't know after investing in the new gas valve that the water heater may decide to leak.
SOURCE: Thermostat not connected for Multi-Stage Furnace.
You need to get a service tech to hook it up for you and yes you need to take advantage of the two speed furnace and varispeed air handler. If it is set up correctly you will be more cpmfortable and will have amuch lower energy bills. Tey are not hard to wire but you have to know what you are doing to do it right. So call Goodman service tech out. Amana is the same product so either one. Should not cost very much and it will pay for the service call in a couple of monthe. Rus
