It will not power on. When I try hard resetting it, it asks if I want factory reset, I select yes. Then it confirms and I select yes again but it does nothing. After a few seconds, it goes back to flashing the logo. How do I fix this?
SOURCE: BlackBerry 8700g Won't Switch On
please try to conect using active sync. see if it detects anything.
SOURCE: IBM T40 Screen goes off after few seconds
survival,
Here's a couple of things to try:
Power down and remove the battery. Leave it out until you are done with the following procedures. Remove the memory modules and put only one back in. Try to power up. If that works, replace the other one and power up. If that works, you're fixed!
If not, try to power up in safe mode and see what happens. If it comes up, try running diagnostics on the HDD. If that fails, try reseating the hard drive.
Let me know how you're coming along on this. May be able to come up with more ideas, if needed.
If you need
any additional information, please feel free to ask. If this information has
assisted you in the resolution of you problem, please return here to give my
assistance an appropriate final rating. If this information has answered your
question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
SOURCE: Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
SOURCE: ricoh aficio 1035 factory rest now unable to get into settings
Press.
and # both simultaneously by but of 10 seconds until it is extinguished,
this restores the values of factory, with luck this had to solve it.
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
