20 Most Recent
LG G4 Questions & Answers
Lg g4 reset
To perform a master reset:
1. Back up all data on the internal memory
2. Turn off the device
3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen
4. Quickly release and the resold the power button while continuing to hold the volume down button.
5. Factory data reset appears
6. Use volume down to highlight yes
7. Press power to confirm
8. Volume down again to highlight yes to erase all user data and restore default settings
9. Press power button to reset device
3/9/2017 1:55:30 AM •
LG G4
Answered
on Mar 09, 2017
LG G4 REPAIR MANUAL
You should not try to power on the phone until it has dried out completely. Drop it in a bag of rice for a couple days. This really is an excellent way of drying up electronic devices.
Here is a link to a teardown and some replacement walkthroughs
https://www.ifixit.com/Device/LG_G4 If it won't turn on and the battery is still sealed, more than likely the board got wet.
7/2/2016 9:51:28 PM •
LG G4
Answered
on Jul 02, 2016
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
