Cell Phones Logo
Addo Marfo Posted on Apr 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lg musicflows6 is stuck on please wait.please how can i solve this problem.
antoniorojas
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Expert 280 Answers
  • Posted on Apr 29, 2019
antoniorojas
Expert
Level 2:
Dedicated:
Answers
280
Questions
0
Helped
69422
Points
668
Hi addo probably you have too much info music videos on your memory cell try to transport more info to your sd memory to check it if you solve the problem
and some heavy apps
try to remove all that you dont use or obsolet
2helpful
2answers
My LG Home Theater is Stuck on Please Wait. How do i fix it
did you try unplugging it, waiting 30 seconds, and plugging it back in?
4helpful
2answers
Boot and please wait problem
I had the same issue twice (2 diffrent devices) on LG Blue-ray HX-906 - stuck on "please wait" after switching it on. It turned out to be defective mainboard - main BGA chip (the one with black radiator) has some problem with connection to mainboard. Here is how to repair it:
- dismount the mainboard
- take off the radiator from the main chip
- put alluminium foil around the chip to avoid unnecessary heating up of other parts of PCB
- heat up the chip using air hotgun to about 200 celsius for about 5 minutes.
Mount everything in reverse order and enjoy
I have the "please wait"
The problem is associated with the Laser / Drive Mechanism.
I take it they told you to :-
1) Unplug and leave for a few minutes.
2) With the On/Off Button Pressed, Plug in and wait for the unit to reset.
If you've done this and still get the same fault then it requires further investigation by an engineer but not necessarily an LG one.
1helpful
My Dream system is DAV FX900W, will not return DVD, only says, please wait.
This is problem of optical lens that got stuck in mid position due to its defective sled motor.
Optical block will be replaced to solve 'please wait' problem in your Sony home theater system.
Let me know if you have additional question.
Thanks.
"Please wait" keep rolling on the display, the LG refuses to work
you need to replace either the mpeg pcb or the dvd loader assy.
The LG DVD it's always saying "Please wait".
Your lens is surely dirty, try cleanign ur lens, nothing else there to do for you.
2answers
LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
1helpful
2answers
Just comes up with "Please wait" it wont load!
I had a RH 178 with the same problem. I opened case and removed the plate with the 2 drive cables and the front lcd cable. Simply wait a few mins and plug it back in, connect the 3 cables and use the 4 srews and VOILA it runs!!
No more "please Wait"
I think it was a connection problem with the "uplink" to mainboard (not the three drive cables and LCD). Can someone please report if it works with his LG?
greets proliant
2answers
Sound
Hey Riya Love,
If I understand you, the LG Combo doesn't transmit music to the speakers. If this is so, then you most probably forgot to connect a lead audio cable from the COMBO to the SOUND port inside your mother board. This cable is most probably still stuck onto the sound port, and the other end hanging loose inside waiting to be plugged intothe COMBO output port. This port is betweenthe power plug and the jumper ports on the COMBO.
Just open the case and do it Riya. Come back if it doesn't solve it.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
