I need to remove the back panel from my samsung UN70KU6300FXZA if unit wont go on check reset lower right bottom
SOURCE: How do I remove the
hi. thanks for the question . 2 screws on the bottom of the front panel .remove these screws . pull on panel, lift from bottom . thanks the appliance doc. please rate this answer. thanks the appliance doc
SOURCE: won't reset/no input on bottom bar
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-P3500?tab=D
Owners manual.
Install Manual Downloads.
May be helpful
SOURCE: remove panel
the freezer panel has 2 fan motors, one for the i/m area and the other for cooling. there is 1 screw in the center of the panel, remove it and then the panel will have to be wedged out. it may seem like it is tight but go ahead and pull on the panel and it will come out.
before you can do this, you will need to remove the drawer and rails so you can get into the panel easily.
p.s. you didnt say why you want to remove this panel???
by the way, these units have problems with the fan motors causing poor cooling in the refr section.
SOURCE: I need to open the back of the Samsung TD220 LCD TV
Care is to be taken? these cases are engineered sometimes with interlocking panels see if you can wedge a a single edge razor blade between the grove of the mated panels and wiggle it see if it moves a little.
If so work it around using danty steps to find the interlocking area the rest is the tought part which one is the release side.
SOURCE: Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
