SOURCE: need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
SOURCE: how do you turn the Ambilight on our philips tv?
Hi guys, I have the same model, and after reasing the manual a little closer and skimming the setup menu I've discovered that it's not actually a built in ambient light, it's actually a setting in the picture menu under "active control" that measures the ambient light in the room and adjusts the picture quality accordingly to ensure the best contrast and reduce glare/reflect imaging. Hope this helps....
SOURCE: where can i find a ir sensor for my Philips
There are plenty of places you can look. Shopjimmy.com. Tiger parts direct. Encompass parts are just a few. Just google the part# and some part suppliers will pop up.
SOURCE: How do I connect external Bose speakers to Philips
can i connect more speakers to a cinemate bose
SOURCE: where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
