Heating & Cooling Logo
Milonda Jones Posted on Apr 21, 2019
My Classic Flame 56" Enterprise Electric Fireplace with sound, and it keeps flashing ( Er) ????? What does that mean?
1helpful
Classic Flame Electric Fireplace. Where can I get replacement parts for it please?
You will probably have to go shopping in China! Apart from Switches and remotes, there appear to be no parts despite there being a parts list.
https://www.google.com/search?q=Classic+Flame+36EB220-GRT+parts
tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 • Heating & Cooling
ClassicFlame 26" 3D SpectraFire Plus Infrared Insert. I bought a SpectraFire fireplace, do I need a 220 outlet for it?
question edited for clarity.
Question moved from Computers.
It is only 1,500 watts so it uses a standard 110 volts outlet in the USA and Canada.
Model numbers are important in these questions. If you are in the UK or South Africa, it will be 220 volts and reflected in a different model number for those markets.
https://www.electricfireplacescanada.ca/efca-products-accessories/plug-in-electric-fireplaces-ca/classicflame-26-in-3d-spectrafire-plus-infrared-electric-fireplace-insert-26ii042fgl.html
The E3 error is a Overheat situation blocked vents, fan not spinning, not enough clearance.
https://www.google.com/search?q=spectrafire+electric+fireplace+e3+code
What does ER flashing mean
ER just means error, so it could be anything. Disconnecting from the mains for 5 minutes is often a form of reset.
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
2answers
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Classic Flame 39EB500GRS Error Message E3?
I had same problem. Just stopped worked and blinked E3. I used the troubleshooting wizard on ClassicFlame's website. Shut power off (it's hardwired to 220v) for a couple minutes and it started back up. Never did find out what caused the error.
Top Heating & Cooling Experts
Paul Carew
john h
