It also has some different names. Regency Ready to Assemble Office in a Box, and Mainstays 3 piece office set
Http://www.regencyof.com/contact-us/
Regency Seating Inc.
2375 Romig Road
Akron, Ohio 44320
United States
Telephone: 1-866-816-9822
Telephone: 330-848-3700
Fax: 1-330-848-6260
Business Hours
Sunday : ClosedMonday : 9:00 am - 5:00 pmTuesday : 9:00 am - 5:00 pmWednesday : 9:00 am - 5:00 pmThursday : 9:00 am - 5:00 pmFriday : 9:00 am - 5:00 pmSaturday : Closed
Many instructions are free online but unable to identify yours.
http://www.regencyof.com/instructions/
I moved you out of computer repair to furniture.
its not a computer so...
the answer is ask the maker of your furniture, or where you bought it. are you in the USA?
SOURCE: changing time (ie. clock) and changing names of lines
Hi Michelle,
To change the time you need to press the 'Prog' button, then press the * key twice, so '**' then enter '1234' then enter '000' then press the 'enter' button (located bottom right hand corner of phone) and this will allow you to change time accordingly.
To change extension name, press 'Prog' button, then press the * key twice (as above), then enter '1234' then enter '000', then enter '004' then press 'enter' button (as above), this should then get you to the spot where you can change the name.
Cheers
AngelXena
SOURCE: office cubicle assembly
Can you post a picture? We may be able to help if we see which model you have. Instructions manual will hard if not impossible to come by.
OC Furniture Assembly
www.ocfurnitureassembly.com
SOURCE: need a manual to assemble a York 1001 multigym.
http://www.yorkfitness.com/store/IIT_dynamicIndex.asp
Follow this link and select appropiate model then download the manual for assembly.
SOURCE: manual settings for mobile office for nokia 3230
Acess point :airtelgprs
Proxy port: 9201
Proxy server: 010.000.000.010
Rest of the fields blank.
Your welcome.
SOURCE: RE essentials bookshelf 5-shelf assembly manual
Hi Jenna:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to
provide you with a real solution at this time.
Hopefully one of other experts will be able to
provide you with a real solution.
Thank you for using FixYa.
