20 Most Recent
Total Gym 1100 Home Gym Questions & Answers
The hitch pin is jammed at an angle and I can't get it out so I can adjust my levels not sure how this happened. How can I get this fixed
Oh no, it sounds like you're having trouble with a jammed hitch pin. That can be frustrating! Here are a few steps you can try to fix the issue:
1. Lubricate the pin: Apply some lubricating oil or penetrating oil to the pin and let it sit for a few minutes. This can help loosen any rust or debris that may be causing the jam.
2. Use pliers or a wrench: If the pin is still stuck, you can try using pliers or a wrench to provide extra leverage. Grip the pin firmly and try to rotate it or pull it out. Be careful not to apply too much force, as you don't want to damage the pin or the hitch.
3. Tap with a hammer: If the pin is still stubbornly stuck, you can try tapping it gently with a hammer. This can help dislodge any obstructions and loosen the pin. Make sure to tap it from different angles to distribute the force evenly.
4. Seek professional help: If all else fails, it might be best to seek assistance from a professional. They have the expertise and specialized tools to safely remove the jammed pin without causing any damage.
Remember to prioritize your safety throughout the process. If you're unsure or uncomfortable with any step, it's always better to ask for professional help. Good luck, and I hope you're able to get your hitch pin fixed soon!
10/8/2023 4:54:30 PM •
Total Gym...
Answered
on Oct 08, 2023
