The hot tub wont keep it at 104 it runs to 116 and keeps running
SOURCE: my washer will not keep water in the tub. The
Hi, You need to make sure the drain hose is as high as the top of the washer. If the drain hose is to low, the water wil drain out before it reaaches the proper water level.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
SOURCE: new (used) hot tub filled with water now it wont stop running
I replaced the upper control panel, and that was the problem.
SOURCE: 2005 kia sedona overheats. thermostat was changed.
does is have cooling system bleed vavle as they might have a air in the cooling system so u will have to bleed it out and if dont have bleed vavle , raidtor fan kicked in working properly me think is ur heating sensor is faulty
SOURCE: My 1994 Acura Legend keeps running hot. Gauge
When the car is completely cool,check the electric fan(s) for smooth rotation.
Clean/check/change the thermo sensor,contact and wire.
Excavate air pocket in coolant system / check for head gasket leak
This test will kill two birds with one stone.
MAKE SURE THE COOLANT SYSTEM and ENGINE IS COLD!
RAN THIS TEST IN A WELL VENTILATED AREA ONLY!
You will spill some coolant during this air pocket purge test.......BE
KIND TO THE ENVIRONMENT and ANIMAL please clean up after the test!
Put the front end on a pair of ramp or park your car on a VERY STEEP HILL (radiator facing top of the hill) .
Top of the coolant reserve tank
Let it ran for 10-15 minutes.
Monitor for air pockets escaping from coolant reserve tank.
Small amount of bubbles is OK at 1-5 minute mark
After the thermostat open up (after 195 F warm up) at
5-12 minute mark or after high idle you should see less bubbles.
If you do not see any in rush of bubbles then your thermostat may be
partially stuck or rusted badly inside the thermostat hosing.
Give the thermostat host few gentle taps.
If you see larger bubbles surfacing after 15 minutes then should do a
hydrocarbon (HC) dye test to test for potential head gasket leak.
Let engine cold down and top off coolant reserve tank.
Start monitor for coolant lost
A coolant flush is require every 2 years or 24,000 miles.
I recommend the thermostat that has a relief pop-let to reduce the change of burst radiator and coolant hoses.
Make sure you get a new thermostat gasket,black RTV and fresh coolant for the job.
Please post more information by clicking the comment link on the top right corner.
DON'T FORGET to RATE ME if my tip is helpful to you!
