SOURCE: Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
SOURCE: Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
SOURCE: Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
SOURCE: Design is ready, when green light is pressed nothing happens
I have had good luck contacting the Singer peoplee themselves. Sometimes it takes a couple of days for them to respond. But, if that doesn't help try this.
Can you go forward a few stitches annd then start?
If not, try condensing your design by 1-2%. This was recommended to me by Singer when I had part of a design that wouldn't stitch out. It did the same as your whole design. I tend to think it is the digitizer, not the machine in my instance. Have you tried another design by a different digitizer?
Hope this helps.
