When the water supply light blinks and the rinse aid light is on in a Bellini dishwasher, it indicates that the dishwasher is not receiving enough water or the water supply is interrupted. Here are a few things you can try to resolve the issue:
Check the water supply: Make sure the water supply valve is turned on and water is flowing properly to the dishwasher.
Check the water inlet valve: The water inlet valve is responsible for controlling the water flow into the dishwasher. If it is faulty, the dishwasher may not be getting enough water. You can check the valve with a multimeter to see if it is working properly.
Check the water pressure: Low water pressure can also cause this issue. Make sure the water pressure is at least 20 psi.
Clean the inlet filter: The inlet filter could be clogged and preventing water from entering the dishwasher. Clean the filter and see if it helps.
If none of these steps resolve the issue, you may need to call a technician to diagnose and fix the problem.
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
The OP manual should have some contact info printed in it somewhere. If not, contact Target to find out who the supplier is. Call the supplier and ask how to contact Bellini.
