Televison & Video Logo
R
Roy Scellato Posted on Apr 10, 2019
How to replace a Samsung UN60JS7000FXZA MAIN BOARD #BN94-09273A
I have a Samsung TV that has no picture just a black screen but can hear the audio. Is this repairable? It is Samsung Model #UN55ES6100F
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung tv un39fh5000fxza inverter needs replacing. Which board is it, and how do I find the correct model number?
Especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Model uahof55ooam has sound no picture model code UA40F500 SAMSUNG TV
My samsung lcd tv ln52a650a1f has no picture what would the most likely cause be?
1helpful
Samsung LED TV half screen is black
How to fix no image problem on my Samsung TV?
Samsung LN32A330J1DXZA will not power on. Problem occurred after moving TV from one house to another. Samsung Capacitor repair came out and pronounced it a dead main board and did not perform any...
reset the c.breaker or replace fuse in the main panel service from your home 2) test the power cord 3) test the switch 4) see if the fuse or c.breaker inside is tripper or replace fuse and try again.
God bless you
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
