Kohler EFI trouble chart.
Suggest you replace spark plugs and air filter if you haven't recently. Check for water in fuel. There is another fuel filter in the EFI system but not likely your problem.
Testimonial: "Already done these. Still have problem."
From Kohler service guide. "Any service to ECU, TPS/Throttle Body (including idle speed increase over 300 RPM), or fuel pump module replacement should include ECU Reset."
https://kohlerpower.com/en/engines/produ...
for reset ECU and TPS relearn procedures.
SOURCE: Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
SOURCE: 05 chevy silvarado duramax engine loses power.
i had a problem similar to this. what i did was i took it to the dealership where i bought it at and it was the EGR valuve that needed to be replaced. i ended up paying about $500 for the whole thing because i had it installed at the dealership. you can order the EGR valuve and install it on your own. it takes about ten minutes to install it.
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
SOURCE: easy start self propelled toro lawn mower won't
it is hard to tell you that but if you take the the bulb plat of and blow it out it should work but make sure that the gasket is in place it well have a small hole ate the top i think fore the air to go threw it
SOURCE: mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
