Garden Logo
Clint Cahoone Posted on Apr 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get to my Craftsman weed eater mod. 316.791860 clutch?
CJ Rock
Level 3:
  • Craftsman Master 4,429 Answers
  • Posted on Apr 18, 2019
CJ Rock
Craftsman Master
Level 3:
Answers
4429
Questions
0
Helped
1645422
Points
15024
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Apr 10, 2009
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Anonymous
  • Posted on Sep 08, 2009
SOURCE: lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Jul 10, 2010
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Feb 19, 2011
SOURCE: hOW TO REMOVE THE CLUTCH
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face
Testimonial: "This is a comple description of what to do. Now i need to do it. Will see how it comes out. Guy fron Quebec, canada"
Anonymous
  • 403 Answers
  • Posted on Apr 16, 2011
SOURCE: My craftsman SimPull 32cc weed
are you switching it from choke, to run ?
Repairing a craftsman ws 2400 2-cycle weed eater 27cc pull rope
This u tube video may help you
https://www.youtube.com/watch?v=G9NM2V27WvY
My Craftsman V20 battery powered weed-eater starts and stops after about 3 seconds. How can I fix this?
  • To fix a weed eater that won't start, check the fuel to ensure that you are using the correct gas-to-oil ratio for the weed eater. Then, you have to change the spark plug. After that, replace the fuel filter. Now, you need to review the starting process of the weed eater.
Where the fuel filter is and how to replace it
fuel filter is on the end of the hose in the tank
Craftsman battery powered weed eater quit working
How old is the weed eater? Does the battery need recharging?
I replaced the clutch because the cutting cord would not turn. It still does not turn. How do I check the cable that runs from the clutch to the head
Doug,
Make or model did not come through with your question...
I guessed Craftsman/Poulan... just for yuks.
so just put the word "TYPICALLY" in front of everything I infer.
The Flex-Shaft is very much like an old fashion SPEEDOMETER CABLE... (some hex.. some square.. all difficult to reseat).
For EASE of FITTING the CABLE BACK into the "drive-sockets"
it would be clever to take the shaft apart at the motor head...
- clean it
- lube it
- inspect & replace if kinked or broken
Most the issues of being jammed up (for me) always came from the business end... It would have a bundle of weeds
VERY TIGHTLY wound around the center shaft...
A good cleaning and clearing usually got me through another couple of FIRE SEASONS.
Good luck & happy whacking!!
http://www.ebay.com/itm/FLEXSHAFT-530095803-PART-POULAN-WEED-EATER-TRIMMER-/390000847153?hash=item5acddca931:g:OT0AAOSwjVVVm99o FLEXSHAFT 530095803 PART POULAN WEED EATER TRIMMER
CRC 03080 White Lithium Grease Spray Net Weight 10 oz 16oz Aerosol
1helpful
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
5helpful
3answers
Manual for craftsman weedeater
how do i take the clutch off my craftsman weed eater model # 358791050 to change the pull string
Apr 11, 2009 • Garden
8helpful
Fuel hoses routed wrong on weed eater fuel tank
Apr 04, 2009 • Garden
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
