I assume by Cart you mean Card. You can put any size card you like in the equipment - however, it will not function unless the card is 2 GB or smaller.
SOURCE: SanDisk Ultra IICF 2.o GB
sorry for the caps- DO NOT FORMAT ANY CAMERA CARD IN A COMPUTER. The card must be formatted in a camera, preferable the one it is going to used on. If in trouble take the card and camera to a photo store and ask them to format the card for you.
SOURCE: 2 gb sandisk card
Yes its only once you go above the 2GB sizes that you hit the SDHC cards wich have diffrent formatting that you would run into problems as you can see in the compatibility sheet here
SOURCE: Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
