Try remove/reinstall magazine.Or contact Arrow.1-800-776-2228Arrow Fastener
SOURCE: i need blueprints for my black and deaker staple gun
You can find and download the product manual here in pdf. If this is not what you are asking for please let me know in further detail what exactly you are looking for.
SOURCE: Need to reassemble Powershot 5700 stapler and need schematic
how to put the stapeler back together after fell apart
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
SOURCE: How do you load nails into a stanley tre550 nail
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
SOURCE: how do you load nails?
The staples
are NOT loaded on top of the pull out shaft; they are inserted directly
into the slot that opens when you pull the shaft out. If the nose of
the tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pull
out the shaft.
Flip the tool over on it’s back.
Insert the staples,
(points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
