Clean it and the fuel lines as well. You may drain it and use a flammable solvent so any residual will burn in the engine after adding fresh fuel...
You should be ok to clean the carburetor out clean the gas tank out and put new spark plugs or clean the plugs real good and it should crank be sure to run clean gas through line to fuel pump to be sure of gas circulation
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
SOURCE: replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
SOURCE: The steering levers quit working on my zero turn
My steering levers on my zero turn toro quite working, The mower wont go forward or in reverse any ideas on how to fix this.
SOURCE: How do I get the belt on the engine back on. Mower will not go forward or back
http://www.partstree.com/parts/toro/mowers-zero-turn-lawn-mower/74631-toro-timecutter-ss-5000-zero-turn-mower-sn-314000001-314999999-2014/belt-and-pulley-assembly/
Give this link a try. Once you have the belt diagram, and the right belt, it has to fit.
