If it gets hot and will not start, the first think to check is the capacitor. The capacitor creates a favorable phase shift on the incoming power and it pushes the motor to spin it at the start winding. Without the capacitor, you don't get that push you need and it does what we call in the field "single phasing". While the term single phasing is usually only used in 3 phase power, you can technically single phase a compressor with single phase power if the capacitor fails because you are losing your favorable phase shift causing in to not spin and overheat. I hope I didn't lose you on my explanation, but I want to try to explain it in a way that is understandable.
You'll have a rating on the capacitor that has a number followed by MFD of uf. This is your microfarid number. Your allowed +/- 6% of the rate capacitor number before is is deemed bad.
You'll need to find someone with a meter that reads microfarids to be able to test the capacitor.
SOURCE: Avanti wine chiller does not chill. Compressor gets very hot.
check the relay on the compressor
SOURCE: 2000 Cadillac DTS suspension air compressor not running, but tests good.
This is a chat room we use as you do from home
Have no wiring diagrams
Helm.Com for GM Factory Manuals
I have bought them for all my veh since 1965 from helm
No reference material your done as you know
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
