The mix of them occurs because of gasket(thin sheet) defect, which is responsible for not mixing the oil & water.. that must be replaced & this service should be done through authorized/qualified service repair person.
BR,
Tamer
Generally the only place a mix could happen like that on a pressure washer would be bad rings on the pumps' piston. This means that if you have an oil reservoir there will most likely be water in there as well.
