Your television source has been changed to OTA and is tuning in the digital channel 2-1. Depending on the TV, there will be a source or input button on the original remote. You either press this button several times to change the source or you use the arrow keys to navigate through the list. You may need to press OK/Enter to confirm the selection. Some TVs also have a source/input button among the TV front panel buttons. Again you press the button several times or use the arrow key equivalents on the front panel to navigate through the list. On a few TVs, changing the source may be inside the on-screen menu. If you have a universal remote, it may match the source/input function. However, this depends on if the best code is programmed. (Some codes for a given brand don't match all of the functions for a given TV.)
Please add a comment with the make/model and the remote (if not the original remote) if you need help changing the source.
