20 Most Recent
Samsung LE40R73BD 40 in. HD-Ready LCD Television Questions & Answers
How to watch movies from usb
If supported by your tv simple put a movie in the root of the USB stick
in .avi or .dvix format then put stick in the tv and it would start the usb player function
3/27/2020 6:34:02 AM •
Samsung...
Answered
on Mar 27, 2020
When you turn on the television when it is on
When you buy a samsung, you buy a LED TV with a panel manufactured
by the company "S - LCD" which belongs to 50/50 % sony and samsung.
The S - LCD company is fully driven under samsung engineering.
Today, sony seems to buy their panels from "sharp corp" and trying to
seperate from samsung due to the cold war (high competition ) between
them.
Just go for the samsung UN32C6500 32" 1080p LED HDTV.
Theres no better picture quality you can buy for 32".
Good luck...
10/25/2019 2:47:35 AM •
Samsung...
Answered
on Oct 25, 2019
Samsung LCD T.V. Problem
You can try samsung.com or you can call 1-800-samsung and try to get to the ECR (executive customer relations) department. They are the people that might be able to help.
12/26/2018 8:11:32 AM •
Samsung...
Answered
on Dec 26, 2018
Hi I have a samsung lcd tv (LE40R7) The picture
It could be some issue in the box itself; e.g. signal/video processing circuit (some cable/satellite/set-top boxes develop weird faults in this area when they get hot which affect channel reception/signal). Resulting in 'digital interference' affecting pictures on-screen.
You could also try another device on your TV (e.g. a DVD player if you have one handy) and see if any issues occur on-screen. If the set does not exhibit the same behaviour with a DVD player, chances are your cable/satellite/set-top box is the likely suspect. (the above suggestion is simply to determine whether the problem exists in the TV, the box, or both)
If it is proven that the box is indeed the culprit, you may have to consider replacing it with a new one as these are cheaply designed and generally non-serviceable.
12/24/2017 4:22:33 AM •
Samsung...
Answered
on Dec 24, 2017
My vizio tv will not turn on
I have repaired many of these over the years. Vizio s have regulators on the main board that have been failing causing this problem. You can verify that the power supply is working by the Vizio em-bloom lighting up on the front of the set. Hope this helps. :)
4/29/2017 5:00:57 AM •
Samsung...
Answered
on Apr 29, 2017
Why won't my Samsung LN40C500F3FXZA turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
7/3/2014 8:37:51 AM •
Samsung...
Answered
on Jul 03, 2014
