is oil filter clogged???
SOURCE: I cannot get the pump to pump water, motor still works.
Sounds like air has gotten into the pump and froze the pump. It will need to be replaced due to that reason. You can get a repair kit for the pump but it will not be gaurenteed to work
SOURCE: My water pump stops and starts. the contacts on
A lot of these pumps do have automatic thermal switches built into the motor end cap, Double check that its being fed the name plate voltage and that the voltage doesn't drop when the pump is running (which would indicate a loose or bad connection or just undersized wire in the circuit)
SOURCE: house pressure water pump has to be reset to
it sounds like a relay for the auto shut off ....http://www.smarter.com/water-pumps/grundfos-mq3-35-3-4-hp-pressure/pd--ch-47--pi-11277834.html
SOURCE: Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
Hi Michelle North, can you please add details in the comment box?
Pump/pressure switch make and models and more details such as distance and vertical feet?
