SOURCE: ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
SOURCE: Need new ribbon
The ribbon code is BR80C. Nu-Kote has a version with a part number of NUKBR80C. You should be able to order it on line at Staples.
SOURCE: WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
