Car Audio & Video Logo
Ha Oumouh Posted on Mar 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix the NG:L R BLBR? - Car Audio & Video
Chris Walker
Level 3:
Top Expert:
  • Car Audio & ... Master 1,573 Answers
  • Posted on Mar 29, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245799
Points
21965
I changed my coil pack and now my car won't idle it's a 2002 Mercury Sable 24 valve
C? n?n ch?n k? tivi treo t??ng b?y tr? ? ph?ng kh?ch ?
Xu h??ng hi?n nay ch?nh l? b?y tr? nh?ng chi?c k? ??c ??o, m?i l?. H?y c?ng ch?ng t?i t?m hi?u v? c?c lo?i k? tivi treo t??ng ? ph?ng kh?ch nh?.
N?u b?n s?ng trong m?t kh?ng gian ch?t h?p? B?n lo l?ng li?u c? ?? kh?ng gian khi b?y tr? tivi ph?ng kh?ch th? ngay t?i ??y nh?ng chi?c k? treo t??ng s? gi?p b?n gi?i quy?t ?i?u ??! th?ng qua website https://kozyhome.vn/danh-muc/ke/ke-treo-tuong/ c?a ch?ng t?i. B?n s? t?m ???c cho m?nh nh?ng m?u k? ?ng ?. Kh?c v?i nh?ng m?u k? ??ng hay k? treo t??ng tr??c ??y. M?u k? treo t??ng tivi gi? ??y ?? ???c ph? c?ch ho?n to?n, n?u kh?ng ?? ? k? b?n s? kh?ng th? nh?n th?y ???c ch?ng. B?i ch?ng ???c thi?t k? g?n ch?m v?o trong t??ng sau ?? ???c m? r?ng kh?ng gian ra b?n ngo?i trong m?t khu v?c, di?n t?ch nh?t ??nh.Vi?c s? h?u nh?ng chi?c k? tivi treo t??ng ki?u n?y nh? m?t ph?n c?a phong c?ch trang tr? ng?i nh?, ch?ng mang l?i nhi?u gi? tr? th?m m? cho ng?i nh? c?a b?n. C?ng ch?ng t?i c?p nh?t nh?ng tin t?c m?i nh?t qua nh?ng trang m?ng x? h?i https://www.quora.com/profile/Ke-KozyHome
Ch?ng gi? cho ng?i nh? c?a b?n ???c ng?n n?p t?t h?n ??c bi?t v?i nh?ng khu c?n h? khi m? di?n t?ch c? h?n. S? h?u k? ?m t??ng ph? h?p trong nh? c?a b?n, b?n s? c? ???c kh?ng gian t?t h?n cho nh?ng ng?i nh? nh? ??ng th?i gian ph?ng kh?ch c?a b?n s? tr? n?n ??p, ??c, l?, g?y ?n t??ng v?i nh?ng v? kh?ch ngay t? c?i nh?n ??u ti?n.
Tuy s? h?u m?t s? ?u ?i?m l? v?y, nh?ng nh?ng m?u k? tivi treo t??ng v?n c? m?t s? h?n ch? m? b?n ph?i l?u ? tr??c khi ra quy?t ??nh mua ch?ng
Vi?c ??u ti?n ?? l? ph?i ph?i ch?n k?ch th??c chi?c tivi ?i sao cho ph? h?p v?i chi?u d?i, chi?u r?ng c?a t??ng ?? khi ta ??a tivi v?o kh?ng qu? to v? c?ng kh?ng qu? nh? ph? h?p k?ch th??c ph?ng kh?ch
Sau khi x?c ??nh k?ch th??c t??ng vi?c ch?ng ta ti?p theo ?? l? x?c ??nh chi?u r?ng, cao ,?? d?i c?a tivi ?i ?? c? th? thi?t k? sao cho cho tivi khi l?p v?o h?c t? th?t g?n kh?t v? ??p m?t. ??y l? m?t ?i?u r?t quan tr?ng ??i h?i ph?i c? nh?ng nh?n vi?n c? chuy?n m?n k? thu?t ch?nh x?c n?u kh?ng s? c? tr??ng h?p h?c t? b? v?nh kh?ng vu?ng g?c, kh? kh?n trong vi?c l?p ??t tivi. Tham kh?o th?m https://blogfreely.net/kekozyhome/
Khi l?p gh?p k? tivi treo t??ng kh?ng th? thi?u ?? ch?nh l? c?c khung treo, m?t chi?c khung ph? h?p s? gi?p tivi c?a ch?ng ta ???c c? ??nh ch?c ch?n h?n. Ngo?i ra b?n c?ng n?n l?u ? thi?t k? c?c h?c t? ph?a sau tivi c?ng nh? trang b? ??y ?? ? c?m ?i?n ?? s? d?ng m?t c?ch t?t nh?t.
1helpful
3answers
Ok my 96 mercury cougar xr7 will not start. It over heated a few months back and I put in a new radiator and thermostat and housing and upper hose and a new battery and it will not start at all tries but...
Make sure battery has a full charge and connections all good. If it cranks good but won't start, have a helper crank it, if cranking rpms sound faster than normal, you may not have any cylinder compression, check compression. Check spark at the plugs--proper fuel pressure--fuel injector pulse? Any applicable trouble codes? Hope the over-heating didn't damage your engine?
I accidentally touched a speaker wire to the metal spikes on the bottom of my speaker. My Onkyo TX-NR757 now reads NG : L R BLBR. I had it biamped so I assume it is both amps. I have tried to reset it...
"I accidentally touched a speaker wire to the metal spikes on the bottom of my speaker. " This action makes +B voltage (positive voltage) short to ground. You may assume 2 power transistors mounted on a large heat sink are defective. Now try to remenber which speaker terminals was accidentially shorted. Then check this terminal or you should check all power transistors mounted on the heat sink, by measuring the collector and emitter resistance. Normal value is Mega ohms and all white 3 pins resistor with 0.22ohm should also be checked if they are open( infinity resistance).I have tried to reset it several times to no avail. Of course, due to defective power transistors. Is my receiver done? Yes. I wrote detailed troubleshooting steps used in onkyo service dept. a year ago, just find it out in my answers.210cda21-872d-438d-949c-2196ccf76712.jpg
For your case, DET. PROTECT: I instead if entering debug mode.forum.php-1foajingjd1ngrzzacwcq31h-2-2.jpeg
NG L R BL BR, This amp is under DC protect.
2answers
Valve clearanc for 2006 cerato G4Ed engine
Ti?ng Vi?t Ti?ng Trung https://daodich.com/pages/phien-dich-vien-tieng-trung-quoc
L? m?t t?i t?i, hay n?i, qua, qua, qua m?t kh?c, qua gi?, qua, qua m?t kh?c, qua, qua, qua, khi kh?c m?i, kh?c m?i, khi kh?c m?i ??ng, m?i, m?i ??ng, m?i ??ng, m?i ??ng, m?i ??ng, m?i ??ng, m?i ??ng, m?i ??ng, m?i ??ng cam cam
36helpful
2answers
I need Cross Fire Cheats 1 hit kill only
bkit ang dya nmn ng ibang ng la2ro sv u gm wla ng cheat bk8 nk2pag cheat p cla
Chức nÄ?ng và ứng dụng
ah this would be like speaking a differnt language that I dont understand what is the problem with your kitchen range? please also include model and serial number as well please write back so that I may assist you in fixing your range
Thanks again
RIck
1helpful
NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
2helpful
3answers
Showing warning psd ng in dvx102 panasonic video cam
PSD NG means that there is a problem with your electronic image stabilization system.I think Panasonic got stuck with a bad batch of gyros. Take it back if you can, otherwise use lower resolution or hold very still when filming.
Pls help me asap
Pwede mong marecord iyan basta naka on ang laptop mo at naka open ang camera mo pero kailangan mong pindutin ang record bottom ng camera. Makikita mo yan pag open mo ng progrram ng camera may nakalagay dyan na record kaya lang di ko alam kung ilang minute lang o oras depende sa setup ng camera mo at free space ng harddisk mo . Ano ba mister mo foreigner at niluluko ka ba tagala.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
