SOURCE: whirlpool front loader
please clarify the "some times throughs the switch" part...does the timing switch continue to run even though the machine stopped?
SOURCE: Whirlpool Front Loader drain pump keeps running all drain positions in cycle
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hello eastax
Welcome
My advice now a days is :
It's really not advisable to fix a dishwasher that old.
It's putting good money into bad!
Here is an article I just read that you may find interesting.
Repair or replace?
When to pull the plug on your dishwasher
Typically, you'll also find a troubleshooting section for more-serious
problems in the owner's manual and on the Web sites of many manufacturers.
Should you pay for a repair or buy a new model? The answer
depends mostly on the age of your dishwasher, how much you bought it for, and
the cost of the repair. Follow these guidelines from our in-house experts:
When a repair makes sense. If your dishwasher is
under warranty or less than four years old ,
paying for a repair makes sense. Note that dishwasher under warranty might
require service from a factory-authorized technician; readers have found them
on a par with independent repairers.
When a repair might be a wise choice. If your dishwasher is out of warranty and is four to seven years old, it might make
sense to pay for a repair. Readers paid $100 to $200 for a repair. But you
might want to buy a new model even at this stage, given that today's models are
quieter and have added features. They pay for them selves in only a few years due to higher energy efficiency which is another plus:
Energy Star-qualified models made after April 28, 2008, are 43 percent more
efficient than conventional models built before 2001 and 56 percent more
efficient than those built before 1993.
When it pays to replace. The repair costs more than
half the price of a comparable new dishwasher. Our data also show that it
doesn't pay to fix a less-expensive dishwasher six or more years
old .
Thanks to better recycling programs, less than 10 percent of
a dishwasher you replace is likely to end up in a landfill.
Thank you for using our services to advice you.
Please remember to leave a rating!
SOURCE: replace the bellow in my front loader whirlpool washing machine
Hello.
You don't need any special tools to do this. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, making sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll find different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you.
Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
SOURCE: f3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
