SOURCE: casio se s300
SE-S300 is having an "Electronic Journal"
1. Key turn to X
2. Press [RC] until u see "EJ"
3. Press [CA/AMT TEND] to print the journal
SOURCE: i want to reset this casio se s300...how can i do?
Reset what? If you mean the daily report, then turn the key to Z mode and press cash. If you are talking about removing programming, it is best to edit the existing programming so you don't lose system settings. If you need a manual, there is one here http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
SOURCE: I bought a second hand register casio se-s300. can
Turn key to PROGRAM mode.
Turn power off at wall.
Hold FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of FEED.
Press SUBTOTAL.
After power on. You are ready to get going.
SOURCE: plz solve my problem casio
If the register is new, this is normal, it just needs programming.
Otherwise, it may have had a lock up.
Try this:
Hold RECEIPT FEED down (may just be called FEED) - keep your finger on it.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
Wait for print out.
Turn key back to REG mode and try it.
If anyone needs more information, the Casio SE-S300 manual is here:
SOURCE: How to reset factory settings on a Casio SE-S300
How do I reset the cash register? 116ER, 117ER, CE2300, CE2350, CE2400, CE280, CE285, CE300, PCR202, PCR204, PCR308, PCR408, PCR350, PCR355, PCR360, PCR365, PCR450, PCR460 This will erase all information - Remove AA batteries and unplug register from wall for 15 minutes.* If resetting does not work this indicates issue is repair level. PCRT465, PCR465A, PCRT2000, This will erase all information - with the PGM key at Off press and hold down the Feed button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros If resetting does not work this indicates issue is repair level. PCRT470, PCRT480, PCRT48S, PCRT2100, PCRT220S This will erase all information - with the PGM key at Off press and hold down the Feed (journal) button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros, now press one of the below 22500 Subtotal (PCRT40, 480, 48S) Or 23000 Subtotal (PCRT2100, 220S ) Wait for a receipt to print. If resetting does not work this indicates issue is repair level.
