SOURCE: i.Tech BlueBand Bluetooth Stereo Headphones
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
