SOURCE: my panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
SOURCE: hi my panasonic sa vk90d
F61 is an error code(protect error code in other brand) for panasonic home theater system. This will trigger if the unit gone to overload to avoid further damaged to other parts. This code is quite technical if your not handy with electronics. However I will say to you the common caused of this error code.
1. Output IC - this is the most common caused of the error code. Once shorts happened to this IC, it will trigger the error code. Exposure to high volume and/or running in the long time will caused this IC to shorts and produce an overload.
2. Shorted Speaker - if one of your speakers shorts, error code will appear also. This may isolate by disconnecting the speaker to the set and play the unit naked. If the symptom still there the fault came from the unit itself.
3. Shorted Inputs - inputs connector is also prone to shorts due to frequent bending and pulling. To isolate this from fault, disconnect all the inputs connected to the unit like the aux input, antenna, mic, etc.
4. Faulty power supply - once gone to out-of-regulation condition, the error code will appear to protect the most expensive parts from further damaged. Bad solder joints in this section is also to consider.
5. Faulty Fan and its circuitry - F61 will appear only after a minute of operation not upon powering on the unit. Check the fan if working or not...
I would advice you to send the unit to your local Panasonic service center and leave the expert isolate the symptoms.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
SOURCE: need spares for my system
A generic request. Spare 'what'? Have you tried the search engines? "SA-VK90D spares"
Ues the lens cleaner to clean the lens. Check the motor belt ,drive gear ,and tray in out setting. you will see something.
