THE FUES IS OK
JBL EON 610 612 615: A factory authorized repair tech told me that this amp module has a power supply that often fails. JBL prescribes replacing the whole amp module, which you can find online from $225 to $262. Sometimes they are backordered. I have (2) Eon610 speakers that no longer turn on (and a 3rd one that is still working), the fuses were fine. The amp module has a 3 year warranty in the USA, so check your receipt, maybe its under warranty. Mine are out of warranty.
Hello Dane, if the fuse is good, you can have the speaker and driver of the horn, open, therefore it will not sound
Hola Dane, si el fusible esta bien, puedes tener el parlante y el driver de la bocina, abiertos, por lo tanto no va a sonar
SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
SOURCE: jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
SOURCE: I have a jbl eon g2 and used it at 1pm and then at
There is nan internal fuse right behind the board were you plug the power cable in. You have to split the cabinet to replace.
SOURCE: what is is the output IC no for the high driver of jbl eon
Download service manual here:
http://www.free-service-manuals.com/JBL_EON15-G2_Service_Manual_L38587/
SOURCE: I have the JBL Eon 515 Speakers.. I found a blown
did you get the problem fixed because iam having a similar problem i have a eon 515 that would not power on
