SOURCE: emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
SOURCE: Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
SOURCE: I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
SOURCE: need wiring diagram for switch.......
try looking at this site .http://www.toolpartsdirect.com/cgi-bin/partbrands.cgi
Hi John Kasecky, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What is the model number and frame size of motor ? It is on the data plate. What you described is the correct way to wire it. You do not want to eliminate switch. Why did you not take a picture of old motor and wiring before removing it?
My boss cut all the wires then passed the buck off to me. So nothing is hooked up. It's for a saw. Its is a dayton 1.5hp 3450 rpm single phase motor. Model# is 6xj53bg
https://www.grainger.com/ec/pdf/6XJ53_3....
https://www.grainger.com/ec/pdf/6XJ53_5....
