TOOK OFF AIR FILTER TO SPRAY CARB CHOKE INTO THE CARB AND WILL KICK IN BUT ONLY FOR A FEW SECONDS THEN IT WILL DIE BACK DOWN.
SOURCE: % hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
SOURCE: Can't get wash fluid to mix/spray out of Honda
I BELIEVE YOUR SPRAYERS ( JETS ) ON THE WINDSCREEN ARE BLOCKED. TO CONFIRM JUST PULL OFF THE HOSE LINE BY THE JETS AND ATTEMPT TO SPRAY.,IF THE WATER COMES OUT QUITE POWERED,THEN THE NOZZLES ARE THE FAULT. WHAT TO DO,IF YOU CAN REMOVE THEM AND DROP THEM IN A VINEGAR FOR FEW HOURS OR IF YOU DO NOT USE THE CAR FOR A NIGHT AND THE NEXT MORNING BLOW THROUGH WITH A PRESSURE AIR FROM THE SPRAYING JET SIDE TO THROW OUT ANY REMAINING. FIT THEM ON AND TRY AGAIN. ALWAYS IN THE MIXTURE OF YOUR WASHERS PUT SOME ALCOHOL.
