Its mechanical- just replace it
good luck
https://www.6ya.com/mrmmike
SOURCE: Ejection Door won't Close
I had the same problem with my 360X.
I took the camera apart and
found two screws loose that hold the tape carrier to the rest of the
chassis. The unfortunate thing is that I had to pretty much disassemble
the entire camera to get to those two screws. It's working again. I'm
assuming those two loose screws were the problem.
SOURCE: subaru door mechanism
okay this how you do it you lift the handle up on the car and you move it back and it should go back only when the handle is up
SOURCE: Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
SOURCE: dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
SOURCE: 2000 Dodge Caravan Rear Door Latch
I had the same problem and fixed it using the following steps. I am not an expert or even very mechanically inclined, just desperate to get this fixed without spending any money. This was done on a 1996 Dodge Caravan. Similar steps should apply to a number of years of the Caravans and Voyagers.
Two people will make removing the panel easier. To do this, you'll need a phillips screwdriver, penetrating lubricant, and pliers.
First, if you cannot open the door at all: There is a small plastic disc plugging a hole just above the latch on the inside. Pop out that disk, and use a screwdriver to lift the latch mechanism. It should not take a great deal of force to move the latch. When the latch moves, push the door and it should open.
1. Remove the plastic panel on the inside of the van. You need to remove the handle and several screws on the perimeter of the door.
2. Disconnect the interior door lights by gently pulling the wiring harness (two of these).
3. Looking at the door from the interior, there is a small electronic plunger mechanism on the right side with an "accordion" (this is the electric lock). There is a rod that goes from the to the middle of the door, just above the lock mechanism. Another rod goes from the key lock to the latch. This rod, threaded on one end, snaps into a small bracket on the latch. It may need to be snapped back in. There may also be a rubbery/tar-like sticker near the locking mechanisms that can be removed (it can interfere with some of the moving parts).
4. Manually operate the plunger on the electric lock several times using pliers. Mine was extremely stiff. It should move the rod at least a full inch.
5. Spray lubricant on the latch, the back of the key lock, and the back of the exterior handle. Also spray lubricant into the key lock itself (where the key goes). Do NOT spray lubricant on the electronic lock mechanism or plunger.
6. Just above the latch, there is a small hole (only about 1/8" around). Carefully and liberally spray lubricant into that hole in every direction (this is where the rods from the key lock, electric lock, and latch meet). There is a white plastic post that comes out through another nearby hole. Spray lubricant liberally into that hole, too.
7. Again, manually operate the plunger on the electric lock several times using pliers. It should be considerably smoother to operate.
8. Put your key into the key lock and pull it out several times.
9. Spray lubricant into the key lock again, then carefully operate the lock with the key. If it didn't work or was stiff before, it should operate much more smoothly. Operate the electric locks several times.
10. When operating the lock, you should see the plunger on the electric lock move to its extents (at least an inch). Watch it when using a key and using the electric lock.
11. Check the movements of the rod and plunger when operating the lock, and the movements of the latch when operating the handle (when unlocked). If anything is still really stiff, use some more lubricant and operate the lock and handle again.
12. When reassembling the door panel, remember to plug in the two wiring harnesses for the interior lights.
I hope this helps!
