SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
SOURCE: Kenmore washing machine Type 111 Model 110
Hi Thanks
for using FixYa. Overfilling in your washer occurs mainly due to two things:
water inlet valve going bad and/or the water level switch. If the water inlet
valve has gone bad it won't be able to shut off even when the electricity has
been turned off. If the issue is with the water level switch then it won't tell
the water to shut off and the machine will overflow as this switch is to sense
the water level in the clothes tub. However, with that being said it seems that
you'll need to replace the water inlet valve. Please rate the solution if the
issue is resolved or post a comment for further assistance. Thanks Rylee
SOURCE: F21 error message - whirlpool duet front loader
Hello, welcome to fixya. Based on your post I understand you have a "F21" error problem with a Kenmore washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know. It is not related to filling. If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is) http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony. Regards, Macmarkus :)
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
