Was old bulb tested after removal? Can you please check the switch?
Testimonial: "bulb filament broken. if you mean oven switch that appears to be working OK. can put light on on own, or turn oven on and light comes on - except it doesn't at the moment"
SOURCE: Change light-bulb
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see http://www.youtube.com/user/Apart4u for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
SOURCE: Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
SOURCE: neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
SOURCE: neff u1661n2gb/05. main oven not working and
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
