Computers & Internet Logo
Hi my 81 year old mother erroneously presses the volume key of her Alcatel 2008G so that it is always on mute. Is there any way I can block that key?
5 Related Answers
Jason Morris
  • 362 Answers
  • Posted on Jan 09, 2009
SOURCE: Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 18, 2009
SOURCE: Have arrived at my 81
slide switch to cool and press doen button to lower the temp to desired temp. Check thermostat to see if it needs batteries by snapping front cover off. Good Luck
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Nov 28, 2009
SOURCE: how to enter service mode
Its press mute on the remote twice. Then for the third time on the remote press the mute on the remote and while pressing the mute that third time press menu on the front of the TV
Testimonial: "the code method you sent me doesnt work any other suggestions would be great thanks Darren"
Anonymous
  • 308 Answers
  • Posted on Apr 16, 2010
SOURCE: I keep getting a very high pitched noise / buzzing
The power supply is a switching mode power supply. They work at high frequencies. Sometimes they produce harmonics that can be heard by people. The power supply may need to be replaced if it get really bad.
Anonymous
  • 183 Answers
  • Posted on Jun 04, 2011
SOURCE: Hi, My Lenovo Z560 laptop has
Welcome to FixYa
The softkey buttons on your system is controlled by the lenovo energy management driver software. Try reinstalling this. You can download it here
www.consumersupport.lenovo.com
Enter the serial number of your computer which is located on the bottom of the system. Look for the S/N number on a white sticker. Dowload and install lenovo energy management. Restart the system and check if that fixes the issue
Hope this helps
1helpful
2answers
How do you turn the volume up on Alcatel one touch 2045
Hi Christine,
Steps to adjust the ringtone volume for calls and text on your Alcatel OneTouch:
  1. Press the Center key.
  2. Scroll to Settings and press the Center key.
  3. Scroll to Volume and press the Center key.
  4. With Incoming Ringer Volume highlighted, press the Center key.
  5. Scroll up or down the preferred volume level.
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
How do I increase volume on an alcatel big easy flip phone?
Hi there
You need to modify the sound settings, select Options > Customize. One of the functions available is :
Volume: Press the Left or Right Navigation key to adjust the volume using the Up or Down Navigation key or volume key on the left side of your phone.
If you have further problems, you can download and save a pdf (Acrobat Reader) version of this phone's manual from here:
Alcatel THE BIG EASY Flip Manual User Guide
Good Luck
Nov 16, 2014 • Cell Phones
ProBook 6450b mute button on keyboard is always orange
Is the volume muted or not when the light is orange? If it is muted then use the icon on task bar and increase the volume, to see if color changes. If it is not muted and a change of volume does not affect the color of the light, maybe that is the normal color for it. Did you read the manual and find that orange means trouble. On my computer, the light for my WifI is always orange.
The speakers may be muted by an Fn +Fx key sequence, or some additional buttons on the computer.
2helpful
3answers
How do i mute incoming call on samsung s7220
Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
Hi i have the extenza web cam on my computer have know idead how to use it help me
Please follow the steps mentioned below:
Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
Thanks and regards,
Anil.B.R
Directv AV1 switch Volume Problem
Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
